2005 Volvo S60 changing headlight bulbs
BOB HARPER
Electrical problem
2005 Volvo S60 6 cyl All Wheel Drive Automatic
Really having diffivculty changing the low beam bulbs.
Should be easy but guess what. I need help. If anyone knows how to go about this I would appreciate some guidance.
Nov 1, 2009 at 8:13 AM
JIS001
  • 3,412 POSTS
What side are you having problems with? Also is this Bi-Xenon or regular hologan bulbs?
Nov 1, 2009 at 8:44 AM
BOB HARPER
working on the passenger side. Getting the bulb out is the problem.
Nov 1, 2009 at 8:55 AM
JIS001
  • 3,412 POSTS
Is it Bi-Xenon or a regular headlight bulb?
Nov 1, 2009 at 9:45 AM
BOB HARPER
I am changing the original equipment bulb for which the replacement is Sylvannia H11 which I believe is a regular headlamp bulb.
Nov 1, 2009 at 10:23 AM
JIS001
  • 3,412 POSTS
O.K. Remove the cover Next twist the bulb counter clock wise and once it is out remove bulb from connector.
Installing bulb low beam
HINT: Look through the glass of the headlamp to align the lamp and twit clock wise to lock back in place.
This bulbs are very difficult to access but you just need a little patience. Good luck to you.
Nov 2, 2009 at 12:23 PM
