I have a volvo s60r turbo charge 5cyl 6 speed when hit full throttle hestitaes or shutters
Jul 14, 2010 at 6:13 AM
JIS001
✓Experienced Mechanic
The first thing is do you see a flashing check engine light? If you see it flashing then you have a severe misfire? You may also want to have it scanned for fault codes to see if there are any codes posted? If you can get the codes and post them on here I should be able to give you an idea as to where your starting point should be?
