2004 Volvo S60 Drivers side mirror memory problem
NEWTGEO
Electrical problem
2004 Volvo S60 Front Wheel Drive Automatic 61,000 miles
Problems with the mirror started after the mirror was replace. It was replaced by a professional body shop after it was side swipped off the car. It moves to random positions when car is powered up. This happens even if we don't change the seat position. Is it possible to disable any automatic positioning of the mirror. Of course we would want to be able to manually adjust usinf the power switch feature. It seams that the internet is liitered with issues of Volvo power mirrors with a mind of their own. Thanks for any input. Not certain how donation system works. This is my first visit here. Please advise on that also.
Sep 13, 2010 at 5:13 AM
JIS001
  • 3,412 POSTS
Did they replace the whole mirror assembly? Also did they get the part from the dealer or aftermarket?
Sep 13, 2010 at 7:56 PM
NEWTGEO
The part was replaced as an entire assembly. No damage was done to the door. I truely believe it was just mounted and plugged in. Their would not have been any internal wiring issues. It was replaced by the insurance companies authorized repair center. I will have to have to investigate if that is a Volvo part.
Sep 13, 2010 at 10:52 PM
VOLVO SERVICE ADV
  • 175 POSTS
IN REGARDS TO THE MIRROR OPERATION, SOMETIMES THERE IS A COMMUNICATION FAILURE IN THE SYSTEM. IF THE PARTS ARE AFTERMARKET, WHICH COULD BE THE ROOT CAUSE, YOU WILL BE BETTER OFF WITH VOLVO PARTS.
Sep 17, 2010 at 2:15 AM
