2003 Volvo S60 oil filter location
GKGRUMPY
2003 Volvo S60
where is the oil filter location and how do you change it.
Oct 1, 2009 at 2:34 AM
JIS001
  • 3,412 POSTS
The oil filter is located on the oil pan. It is inside the black canister on the pan. You need a secial tool that will fit on the housing to remove it. If you try using pliers you will break the housing since it is made of plastic.
Oct 1, 2009 at 4:04 PM
