2003 Volvo S60 Maintenance
SHRINK85
Engine Mechanical problem
2003 Volvo S60 Manual 127,00 miles
Where is the engine oil filter located and how do I change it.
Apr 2, 2010 at 2:57 AM
JIS001
  • 3,412 POSTS
Oil filter is a canister filter and is located inside the oil pan. You will see the filter housing, a black plastic housin. You will need a special tool that fits around the housing to remove it. Do not use pliers to try and remove or you will crack the housing open. Call your local parts store to see if they have the tool you can rent.
Apr 4, 2010 at 10:19 AM
