2003 Volvo S60 Clunck
CHIEFIRONSIDES
  • 2003 VOLVO S60
  • 4 CYL
  • FWD
  • MANUAL
  • 24,000 MILES
This is not so much a noise as a gentle clunck. It is most noticeable at slow speed when the throttle (torque)is applied or released. Either way the noise is the same when the throttle is just dipped slightly or is released.
Thursday, May 8th, 2008 AT 7:46 AM
BLACKOP555
  • 10,371 POSTS
Either suspention components and bushings are worn or loose, or there is wear in the gears of the transmission.
Check all bearings and components for looseness or wear, then have a transmission shop check it over if nothing is found.
Wednesday, July 16th, 2008 AT 3:42 PM
Related General Content
