2002 Volvo S60 Timing Belt Replacement
58,000 MILES • 6 CYL • FWD • AUTOMATIC
LINDALYNCH22
It is not suggested to replace timing belt until around 100,000. However, since my car is 7 years old with only 58,000, should I go ahead and have it replace. my Volver dealer service dept said it was drying out due to age. If replaced, is there anything else I need to do since timing belt requires engine to be pulled (I think). Thank you.
Apr 30, 2009 at 11:42 AM
BMRFIXIT
  • 19,053 POSTS
If the belt was inspected and its drying out and cracking
than I would for sure recommend having it replaced
inspect pulleys and drive belts too
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 30, 2009 at 12:02 PM
