2002 Volvo S60 P0037 dtc code
80,000 MILES • 6 CYL • FWD • AUTOMATIC
M88CAP
What does HO2S Bank 1 Sen 2 Heater Circuit Low mean and can I fix it myself?
Jun 29, 2009 at 9:32 AM
JIS001
  • 3,412 POSTS
I am not sure where your from but the S60 comes with an inline 5 engine and not a 6 cylinder? to fault trace if it is sensor 2 then you need to check the oxgen sensor in backof he catalytic converter.
Check the resistance of the heated oxygen sensor (HO2S) between terminals #1 and #2.
Check the signal cable between heated oxygen sensor (HO2S) terminal #2 and control module terminal #A6 (#A6). Check for a short-circuit to ground.
If you have no resistance at all between #1 and #2 terminals on the sensor itself then the heating element insdie the sensor has gone open circuited so you will need to replace the sensor.
Jun 29, 2009 at 6:26 PM
