2002 Volvo S60 High Pitch Squeal noise and RMP dropping
SHAYNAMILLS
2002 Volvo S60
My car makes a horrible loud high pitch squeal noise near the manifold and belts area and when it gets put in park the RPM's drop very low and come up a bit but sounds like it's about to stall out any second but hasn't. It has done this a few times and when I start it back up the next day the sound is gone and it runs fine?
Any suggestions on what it could be?
My husband said to describe the squeal as more of a wharring sound, not sure if that makes sense.
Dec 5, 2008 at 4:06 AM
JAMES W.
  • 2,394 POSTS
Sounds like a lose alternator belt. Check to see if all belts are tight and in good shape. I could be the idler bearing on the A/C compressor, but I doubt it. Please advise.
Dec 5, 2008 at 4:15 AM
JWTUCKER23
  • 5 POSTS
you need to have the throttle body cleaned on it ive seen it many times. if it has less that 150000 you can call the dealer and they should clean it under warranty. let me know how it goes jwtucker23@yahoo.com.
Dec 24, 2008 at 5:33 PM
