2002 Volvo S60 Display
2002 VOLVO S60
FANU_ON
Electrical problem
2002 Volvo S60 Four Wheel Drive Manual 136000 miles
Hi, i have a problem with the display from the dashboard(the computer). it doesnt show nothing...sometimes its show the writing very cranky or on and off, but most of the time its off. any ideeas what could be?
Jun 19, 2009 at 7:09 AM
JIS001
  • 3,412 POSTS
You should take it in to Volvo. Sounds like the cluster itself may be going bad? You can remove it yourself and check that the connectors are making proper contact but if the cluster needs to be replaced then Volvo will need to replace it since they need to load the software an enter important information like the right mileage you have now, tire size for the speedo to be accurate. Either way they need to diagnose to make sure tht is the problem and not a problem with the low speed CAN BUS? Do you also have SRS and maybe ABS light on as well?
Jun 20, 2009 at 5:33 PM
