After the car has been running for about 30 minutes the A/C continues to run, but the air is warm.
Sunday, July 18th, 2010 AT 6:15 PM
JIS001
MECHANIC
Have the A/C compressor clutch clearance gap checked. Spec is 0.3mm t 0.5mm if you can insert a feeler gage thicker then 0.5mm then you need to remove the clutch and and remove some of the shims to closethe gap in. If removing the shims does not get it back into spec, then you will need to replace the clutch.
