2001 Volvo S60 Message or Idiot Light Messages
11,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMES A. DAVIS
I am getting this Message: Bulb Failure, Position Light. I'm not sure what Position Light means. I cannot find the bulb or light that is causing this Message, so that I can replace it. Can you help me with this...ie. location, way to track to specific bulb/light problem. Thank You
Jul 25, 2008 at 6:41 AM
ELSORTZ
I have a 2001 Volvo s60 2.4t and that was a message that popped up on me when I would washed my car. I notice that the passeger side turn signal on the outside of the car was loose and water pressure was entering inside. I took it to a Volvo dealer and had them replace the part which was broken and Never had the problem again. Check all your lighting bulbs on the car, may need to replace one.
Aug 10, 2008 at 7:18 AM
