2001 Volvo S60 Dashboard cup holder broken
101,000 MILES • 4 CYL • 2WD • AUTOMATIC
WOODGAJW1
[img:74077c7922]http://www.2carpros.com/forum/automotive_pictures/560088_SDC13731_1.jpg[/img:74077c7922]
The dsahboard cup holder of my 2001 volvo s60 has popped out and will not remain closed when pushed back in.
How do i remove the unit in order to repair or replace it?
Aug 10, 2010 at 4:37 AM
JIS001
  • 3,412 POSTS
It is a little difficult to explain but if you buy the cup holder and look at the tabs you will get an idea on how to remove it. You will need a hook type tool and a weather strip tool. With the weather strip tool you will need to gently pry to locate the locking pin. When you do, you will need the hook to pry on the locking tabs and pull out the cup holder. To install you just push in the new cup holder in.
Aug 11, 2010 at 1:45 PM
