2001 Volvo S60 cv joint
ESTRELLA1229
Drive Train Axles Bearings problem
2001 Volvo S60 6 cyl Two Wheel Drive Automatic
my cars cv joint axle broke im having problems removing the cv joint at the end do you have any tips i can use to help me remove it or what special tool can i use
Jun 10, 2009 at 10:55 AM
JIS001
  • 3,412 POSTS
If you are talking about the end that goes into the transmission usually you can pry it with a pry bar. Sometimes you may need 2 of them and pry back and forth alternating from one pry bar to the next.
Good luck.
Jun 11, 2009 at 10:35 AM
