Well seems like you really dont know a Volvo after all? Just 2 months ago had a 2009 S80 with both outer brake light bulbs not working. Of coarse first thing that popped in my mind was it could have a bad relay right? WRONG!!!!! Just for the heck of it decided to check the bulbs. Removed bulbs from socket and probed with a test light and guess what? The bulbs were bad. Never forget your basics or you will look like a fool if you can not even diagnose a simple bulb failure. Start with the easiest part first and sounds like he is. Bulbs burn out, replaces, and burns out. You should know that cheap bulbs from a cheap aftermarket manufacture will not last? So, ljones30082 before you go to the dealership and spend a $100 diagnosis for bulbs, check them again yourself and like I mentioned before, do the basic tests I have provided an let me know what you find.
Oct 29, 2010 at 3:40 PM
