Volvo S40 2001 90K miles
2001 VOLVO S40
ROSLYNBROWN
I just bought a used S40 for $6K w/ 90K miles.
1.) Antenna broke off. Is it easy for a novice to replace?
2.) Check engine light is on. Code says bank 1 oxygen sensor is bad. Should I buy the whole sensor for $150 or just the sensor for $40. Should I also replace the bank 2?
3.) I just replaced the fuel pressure regulator because the car was fluttering before it would start. Once it started, it was fine.
4.) Everytime I turn on the car, the clock/mileage resets to 12:00 pm. Is this a mechanical issue?
5.) I replaced the bulb on the interior map light but it still will not come on?
6.) When I open the hood there is a blank spot near the rear, in front of this thing that looks like an aluminum square pan. Am I missing something?
Many thanks!
Feb 12, 2007 at 5:55 AM
BLACKOP555
  • 10,386 POSTS
depends on where it broke off.
whole senesor or sensor? buy the whole sensor if you cant solder good and dont have the time.
you mean a hard start problem?
have to check in that
is bulb recieivng power?
what?
Jul 15, 2008 at 3:43 PM
