A/C blowing warm air
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
KIPSYLOLA
While driving down the road my A/C starts blowing warm air, after a while it will start blowing cold air again.
A local mechanic said that it had freon and he couldn't see any issue? Please Help....
Jul 25, 2010 at 2:32 AM
  • 75,988 POSTS
Could be feezing up blocking the orifice tube, low pressure switch, temperature sensor and AC control module.
Jul 25, 2010 at 8:10 AM
JIS001
  • 3,412 POSTS
Check the compressor clutch clearance. Spec is 0.3mm to 0.5mm Very common for this to wear down. Always replace them for that reason.
Jul 25, 2010 at 5:20 PM
