2005 Volvo S40 Removing Intake Manifold
2005 VOLVO S40
74,000 MILES • 4 CYL • 2WD • AUTOMATIC
ESCHER
How do I remove the intake manifold?
Jul 5, 2010 at 3:12 AM
JIS001
  • 3,412 POSTS
Is this turbo or none turbo? And why is it you want to remove the intake manifold?
Jul 5, 2010 at 1:24 PM
ESCHER
I wanted info on removing the fresh air intake housing because I needed to remove the oil filter housing for suspected blockage. Problem solved - it turned out to be a cracked hose, all better now, thanks.
escher
Jul 5, 2010 at 4:00 PM
JIS001
  • 3,412 POSTS
I had a feeling you were going in that direction? The oil trap box and hose could have being covered by an extended emissions warranty of 10 years/150k miles? It should be on your owners manuel but you can verify it by calling Volvo and givng them the vin#?
Jul 5, 2010 at 5:24 PM
