2005 Volvo S40 heat on passenger side staying hot.
2005 VOLVO S40
64,000 MILES • 4 CYL • FWD • AUTOMATIC
SANTORDW
When the heat is turned off after use, the passenger side is staying on hot. Why? can you help with this.
Oct 13, 2010 at 1:32 AM
JIS001
  • 3,412 POSTS
You could have an issue with the passenger temp damper motor or the blend door is jamming up. The first thing you may want to have done first is to see if they can recalibrate the damper motors. Usually you need to do it aout 2 to 3 times to force it to take the calibration. If that does not work, they need to inspect the motor to see if it is bad? If the blend door is what is faulty, then the whole dash needs to come out to replace the climate control box.
Oct 13, 2010 at 2:19 PM
