2005 Volvo S40 Gear Selector Service
CORTES78
Transmission problem
2005 Volvo S40 Front Wheel Drive Automatic 67000 miles
when selecting gear the reverse works then when selecting drive it gets stuck on neutral.Then about 5 minutes pass then you can select drive.they say it can be a sensor or a relay.I havent taken the car to a dealer yet,Im afraid it can be something major because i dont have the money right now to fix it or get a diagnostic check up.I will soon be able too but it will be great if i had a heads up first on what im dealing wit and a estimate on how much could it cost.
Nov 9, 2008 at 8:21 AM
  • 55,688 POSTS
Hey CORTES78,
Yes this does sound like bad news for the transmission, what happens is the seal inside the unit become worn for the forward gear set so they do not work when the transmission is cold. When is warms up the seal expand which allow the transmission to work again, it sounds like it needs a rebuild.
Please let us know what happens so it will help others
Best, Ken
Jan 30, 2017 at 5:26 PM
