Timing belt
2003 VOLVO S40
HM
Four cylinder front wheel drive automatic 75,000 miles.
I have change the timing belt, but I need what it is distribution time?
Could you help me?
HM
Nov 16, 2009 at 4:15 AM
JIS001
  • 3,412 POSTS
Are you asking for the timing marks?
Nov 18, 2009 at 4:18 PM
HM
Yes, it is about timing marks.
Thanks.
HM
Nov 18, 2009 at 11:35 PM
JIS001
  • 3,412 POSTS
https://images.2carpros.com/forum/automotive_pictures/337695_94855773_1.jpg
Remove the right front wheel. Position the upper timing cover. Turn the crankshaft until the markings on the crankshaft and camshaft pulley correspond. Turn the crankshaft a further quarter turn clockwise and then back again until the markings correspond. The markings are illustrated. Remove the upper timing cover. The crank sprockets have two notches on it. There is a dimple on the block and it needs to be in between those two notches. When you install belt and tighten the tension-er down turn engine by hand a couple of revolutions and make sure all marks line up again.
https://images.2carpros.com/forum/automotive_pictures/337695_105960441_1.jpg
Nov 19, 2009 at 4:16 PM
Hi, I just want to see how to place the double cams on the timing marks for Volvo s40 2004 model. show the video ,if possible.
Sep 16, 2014 at 6:43 PM
