2003 Volvo S40 starter ?
2003 VOLVO S40
SM3279
Engine Mechanical problem
2003 Volvo S40 4 cyl Front Wheel Drive
I replaced the spark plugs and the thermostat in my volvo s40 2003 today and now the car will not start. The lights and dash come on but the car will not turn over, help !
Jan 1, 2010 at 8:54 AM
Do you mean it cranks over and will not start or just won't crank at all/nothing/nada?
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Jan 1, 2010 at 9:04 AM
