2003 Volvo S40
CARMINE34
Can I change the front pass side wheel bearing myself or is it too involved? Too much to take apart?
Also need a rear control arm changed, can I change it myself?
Thanks,
CAC
Oct 25, 2007 at 2:43 AM
BLACKOP555
  • 10,386 POSTS
should be able to change the control arm.
for the bearing you will need to remove the wheel bearing assembly and have a shop press it out and put in a new one. unless you have a press.
Jul 15, 2008 at 3:47 PM
