2001 Volvo S40 serpentine belt coming off
2001 VOLVO S40
GROJAS
2001 Volvo S40 4 cyl Front Wheel Drive Automatic
fixing car somebody else tried. serpentine belt elapes off the power stering pulley crankshaft pulley not matching other pulleys by 3/8 or 2 ribs, harmonic balencer pully only goes in one way, checked pulley on crANK ALL THE Way in.
Nov 2, 2010 at 11:27 AM
JIS001
  • 3,412 POSTS
Before you got the vehicle, what was removed and why was the serpentine belt off? Were they replacing a faulty component?
Nov 3, 2010 at 5:00 PM
GROJAS
because timing belt not set corectly
Nov 9, 2010 at 4:10 AM
JIS001
  • 3,412 POSTS
Make sure the crankshaft pulley was installed properly. They could have installed it backwards and can be easy to do. If it is just remove the crankshaft pulley nut, use a pry bar to pry off the pulley and turn it around. Let me know what you find.
Nov 9, 2010 at 12:08 PM
EBON_EB
I am having the same problem....I had the tensioner replaced....and have returned to the same shop three times for them to put it back on again.....please tell me what to do or check.
Jun 2, 2012 at 4:55 PM
