i have prob..when i put my food down car starts coughing..for a little while than it goes to normal..it`s a bit laisy engine too
Nov 1, 2009 at 1:53 AM
JIS001
✓Experienced Mechanic
Is your check engine light flashing while under load?
Nov 1, 2009 at 8:38 AM
STARNET
MEMBER
no ther `s no ligth flash at all.. and car always couhging when I drive slow with high gear..
Nov 2, 2009 at 3:21 AM
STARNET
MEMBER
thanks for quick respond sir.....u guys r marvelous
Nov 2, 2009 at 3:32 AM
JIS001
First thing you need to do is have the engine control module scanned for codes. If you do have codes it could be related to your problem. Also if there are codes can you post them up here.
Nov 2, 2009 at 12:01 PM
