2001 Volvo S40 idle problem
LOURENS 7880
2001 Volvo S40 4 cyl Front Wheel Drive Automatic
i have a volvo s40 t4 with idle problems . when i start the car it starts and then cuts out , the problem is the same cold or working temp , i replaced MAF sensor , idle control vave , throttle body , throttle swith (tps) , all vacuum pipes 100% and theres no vacuum leaks on the intake manifold
Aug 31, 2010 at 5:12 AM
LEGITIMATE007
  • 5,121 POSTS
you will need to test for fuel pressure and spark. in order to figure this out.
Aug 31, 2010 at 11:33 PM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
