cylinder number sequence
2001 VOLVO S40
CRMORRISON
Engine Performance problem
2001 Volvo S40 4 cyl Front Wheel Drive Automatic
In 2001 Volvo S-40 1.9T, are cylinders numbered from (facing windshield) right to left or left to right? - Misfire cylinder 4 code.
Sep 13, 2010 at 7:49 AM
Hi crmorrison,Welcome to 2carpros and TY for the donation-this is what keeps the site going. Check spark plug,compression and fuel injector on #4 cylinder.See below:
https://images.2carpros.com/forum/automotive_pictures/12900_fo_149.jpg
This diagram is wrong for Volvo s40 2001 1.9 turbo...the plug wire firing order is 1423..not 1342. thanks
Sep 13, 2010 at 10:06 AM
VOLVO SERVICE ADV
  • 175 POSTS
if engine is misfiring, you may just need to replace the ignition coil and spark plugs. "misfire" fault typically does not mean the engine has a compression issue.
Sep 16, 2010 at 12:38 PM
