2001 Volvo S40 Add transmission fluid
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAINBOWSALES
  • 5 POSTS
Where do you add transmission fluid?
Jul 14, 2009 at 5:48 AM
JIS001
  • 3,412 POSTS
The dipstick is hard to get at. When cold if you push thelower radiator hose to the side you should see the yellow dipstick. If you try it when it is hot you will get burn Also make sure you use the proper fluid. If dipstick says to use special oil then you will need synthetic transmission fluid.
Jul 14, 2009 at 4:45 PM
TEXASPOINTS
Where exactly is the lower radiator hose? Is this where transmission fluid is added? Thanks for the help.
Dec 19, 2010 at 11:27 AM
JIS001
  • 3,412 POSTS
If you look at the radiator on drivers side. Look below and you will see the radiator hose. Gently push it to the side and you should see the dipstick down below on the transmission.
Dec 20, 2010 at 10:53 PM
TEXASPOINTS
Thanks for the help. Now, where do i add transmission fluid. Let me explain my issue. I had my car shipped by cargo ship and when it got off the ship it would not go into gear. What I am trying to do is see if for whatever reason the fluid leaked out during the voyage. So, I want to add fluid and see if it leaks out. Thanks again.
Dec 21, 2010 at 9:21 AM
JIS001
  • 3,412 POSTS
You fill it in the same place you check it.
Dec 21, 2010 at 9:41 PM
KHLOW2008
  • 41,812 POSTS
Always remember to check the fluid after running to operating temperature.
Feb 14, 2012 at 5:37 AM
