Water is getting into my oil in the engine
11,500 MILES • 4 CYL • FWD • AUTOMATIC
JHON32714
Are there any reasonable solutions to fixing this problem? The Volvo runs hot after about five minutes.
Aug 31, 2010 at 6:16 AM
LEGITIMATE007
  • 5,121 POSTS
if your getting water into the oil then you most likely need a intake manifold gasket or head gasket.
Aug 31, 2010 at 11:30 PM
VOLVO SERVICE ADV
  • 175 POSTS
It sounds like the engine has overheated. Once engine has overheated, the headgasket weakens and allows the mixture of oil and coolant. Check dipstick, if dipstick is milky, there is probably too much coolant in engine already. Only solution you have is to remove the cylinder head and replaced the gasket. Make sure you have somebody due a pressure test to verify headgasket is leaking. Good luck!
Sep 16, 2010 at 11:52 AM
LEGITIMATE007
  • 5,121 POSTS
I appreciate your input "service adv"
Sep 16, 2010 at 12:05 PM
MERCYAMARACHI
Hello, water still mixes with the oil in my 2000 Volvo S40. Even after changing the gasket. Any other solutions will be helpful. Thanks
Nov 26, 2018 at 10:11 PM
