2000 Volvo S40 timing
TAZZWALSH
Engine Performance problem
2000 Volvo S40 4 cyl Front Wheel Drive Automatic
i just replaced my head gasket,know i am trying to set my timing is there any markings on the cams or any were to set the timing?how is the timing set?????
May 15, 2010 at 11:21 AM
JIS001
  • 3,412 POSTS
If you removed the cvvt hub on the exhaust cam then you will need the cam locking tool to set it up. Attaching the timing marks and where the tensioner needs to be set up.
https://images.2carpros.com/forum/automotive_pictures/337695_94855773_2.jpg
https://images.2carpros.com/forum/automotive_pictures/337695_105661348_1.jpg
May 16, 2010 at 2:07 PM
TAZZWALSH
thank you for your input it was very helpful.do you happen to know the torque specs on the headbolts and the valve cover bolts.thanks again.
May 17, 2010 at 4:41 AM
JIS001
  • 3,412 POSTS
Make sure you are using new headbolts and you oil the bolts so that they dont bind up. first step 20Nm seconde step 60Nm and finally 3rd step angle torque to 130 degrees.
https://images.2carpros.com/forum/automotive_pictures/337695_86344857_1.gif
May 17, 2010 at 8:24 AM
