Engine Cooling problem
2000 Volvo S40 4 cyl Two Wheel Drive Automatic
Is there are any information should be entered in the car computer after replacement of IAT and thermostat kit.
Sunday, October 4th, 2009 AT 8:49 PM
JIS001
MECHANIC
I don't know about the IAT? Why did you replace the intake air temperature sensor? Also why was the thermostat replaced? Was there a trouble code stored PO128? If you did and thermostat is ok and engine coolant temperature sensoris ok then you would need to take it in to Volvo to have the engine control module reprogrammed with an upgraded software if it is available. The reprogram is pretty long and the longest I have seen it take is about 4 hours to do.
