2000 Volvo S40 'Puttering' Problem With Car
120,000 MILES • 4 CYL • FWD • AUTOMATIC
EW68071
Recently my Volvo S40 (2000) has started 'puttering' when I accelerate. The 'puttering' is more of a jerking, but if I let off the gas and accelerate slowly it is okay. Also, when I'm accelerating up a hill the 'puttering' is extremely noticable and I almost have to stop the car. In addition, if the 'puttering' or jerking persists the "Check Engine" comes on and starts to blink until I let off the gas. Any ideas? Thanks so much!
Apr 18, 2008 at 5:38 AM
BLACKOP555
  • 10,386 POSTS
sounds like a issue with the MAF sensor, scan it for codes and get back to me.
Jul 15, 2008 at 10:45 AM
WHITELAKE86
the problem is most probably one or more of your ignition coils its about a 50 $ part (for each) and its very easy to change have your computer scaned and if it tells you about a cylinder misfire than its 99 percent that its your ignition coil the cylinder misfire that it mentions the most times is probably the one you need to change
Aug 5, 2008 at 10:02 AM
