2000 Volvo S40 oil leak
HOWARD FRENCH
  • 2000 VOLVO S40
  • 4 CYL
  • FWD
  • 91,000 MILES
Oil is leaking from a metal tube @ the rear of the oil pan just above a bolt.
Monday, August 11th, 2008 AT 1:29 PM
KHOOPER
  • 22 POSTS
As the gasket gets older it shrinks, try to tighten the bolts before you take them down again. Also, your real main seal could be leaking if the oil is coming out of your clutch cover inspection hole.
Thursday, August 14th, 2008 AT 10:00 PM
