2000 Volvo S40 Noise & Vibration
2000 VOLVO S40
97,000 MILES • 6 CYL • FWD • AUTOMATIC
SMITCHELL77
when driving speed above 60mph. Car has a lot of vibration. Noticeably more when going up a hill. I was thinking maybe the motor mounts or plugs. What do you thinkg. Tires are ok.
Nov 9, 2010 at 6:24 AM
VOLVO SERVICE ADV
  • 175 POSTS
IS THE VIBRATION ON ACCELERATION?? OR IS THE VIBRATION WHEN YOU ARE COASTING AT 60MPH? IF THE VIBRATION IS WHEN JUST DRIVING ABOVE 60MPH, IT MAY BE DUE TO A TIRE BALANCE ISSUE. IF THE VIBRATION IS WHEN ACCELERATING, THIS COULD BE RELATED TO A FAULTY AXLE. CAN YOU GIVE MORE INFO?
Nov 9, 2010 at 11:12 AM
JIS001
  • 3,412 POSTS
Is there a flashing check engine light with that?
Nov 9, 2010 at 12:14 PM
SMITCHELL77
[quote:a6c7f2cf84="VOLVO SERVICE ADV"]IS THE VIBRATION ON ACCELERATION?? OR IS THE VIBRATION WHEN YOU ARE COASTING AT 60MPH? IF THE VIBRATION IS WHEN JUST DRIVING ABOVE 60MPH, IT MAY BE DUE TO A TIRE BALANCE ISSUE. IF THE VIBRATION IS WHEN ACCELERATING, THIS COULD BE RELATED TO A FAULTY AXLE. CAN YOU GIVE MORE INFO?[/quote:a6c7f2cf84]
vibration is on acceleration, when coast of a hill to speeds faster no vibration, Had a note from earlier service about motor mounts...
Nov 10, 2010 at 1:04 AM
SMITCHELL77
[quote:e768f11da7="JIS001"]Is there a flashing check engine light with that?[/quote:e768f11da7] No warning lights everything looks great...
Nov 10, 2010 at 1:06 AM
VOLVO SERVICE ADV
  • 175 POSTS
MOTOR MOUNTS CAN CAUSE A VIBRATION, BUT THAT WOULD BE MORE AT IDLE. YOU CAN CHECK THE AXLES FOR PLAY, IF THEY HAVE TOO MUCH PLAY, THEY CAN CREATE A VIBRATION WHEN ACCELERATING OR WHEN VEHICLE IS UNDER LOAD.
Nov 10, 2010 at 1:13 AM
