Check to make sure you did not knock a wire loose by acident around the fuse box area. Check the 30+ wire in the fuse boxs also and make sure that is ok. Check battery cables and make sure the are on tight and clean. Check solenoid wire to starter also. Make sure that is secured. If it is, while someone turning the key to the run position check for battery voltage. If there is no voltage then you will need to get a wiring diagram to further fault trace.
Jan 30, 2010 at 7:19 AM
