2000 Volvo S40 Headlights
2000 VOLVO S40
JK1705
Electrical problem
2000 Volvo S40 4 cyl Front Wheel Drive 125000 miles
Headlights will not turn off even after ignition is turned off. Any suggestions?
May 20, 2009 at 1:42 PM
JIS001
  • 3,412 POSTS
Your light switch could be bad? Remove the switch and unplug it. If the lights go out plug it back in with the switch in the off position and see what happens with the lights. If they come back then you will need to take it into the shop for proper diagnosing and fault trace for a possible short.
May 20, 2009 at 6:17 PM
