1998 Volvo S40 Water Leakage
1998 VOLVO S40
KRISTOS T
Engine problem
1998 Volvo S40 Engine Size unknown Wheel Drive Type unknown Automatic 94118 miles
Hi there, I have a 1998 Volvo S40. Last year I wasn't watching the road and ran over a crate, which smacked up to the bottom of the car, hitting the oil filter. The oil light came on on the dash but I stupidly thought it would be ok and kept driving. Just as I got home the entire motor shut down. Took it to the mechanic and turns out I had seized the motor.
Long story short, it takes them 5 months to fix it (they replaced the entire motor, at a cost of $4.5k)and since I live in New Zealand, we have to wait for the parts to come from Europe. I finally get it back, and it cuts out on me, take it back and it turns out one of the fuel pipes was a bit looser when they were repairing it. So they tighten the pipe, and all good, then it won't start. Turns out that sitting in the mechanic's for 5 months leads to a dead battery. So I replace it and it works no worries.
However now I have noticed, that after driving it for a bit of time, say 20 minutes or so, and then park it, it leaks water below the car. I have no idea how this is happening and where it is coming from, but I always make sure I top up the water everytime I stop. As it is a volvo instead of the radiator being at the front, it is in the back right corner. I am worried that this leaking will cause the motor to overheat. I have a feeling the radiator might have a crack but have no idea what to look for. I am hesitant to take it to the mechanic's because I have already spent so much on it. What do you suggest I do?
Cheers very much
Oh, and it is an import from Japan as well, so it has no manual
Feb 18, 2008 at 8:15 PM
MERLIN2021
  • 17,250 POSTS
Is Water or coolant leaking? Is it coolered the same as your coolant? or is it water? Coolant when you feel it is slippery, then sticky, water...well you know! If it's only water, it could be the condensate from the a/c drain. If it's coolant, have a pressure test done while your engine is under warranty?
Feb 19, 2008 at 12:13 AM
KRISTOS T
I'm pretty sure it's coolant that's leaking. Where I put water normally, its a green colour. When I have seen leaking below the car, it is green and slightly sticky. It's a brand new engine so I assume it's under warranty, do you think it could be the radiator at all? It annoys me cuz I always have to top it up when I stop.
Feb 19, 2008 at 7:38 AM
