1998 Volvo S40
1998 VOLVO S40
66,000 MILES • 4 CYL • 4WD • MANUAL
CHELLEBROWN1982
we had new brake pads and a rod for front pasenger side few months ago but now when we brake its making an awful noise like somthing has fallen
Oct 4, 2010 at 10:57 PM
VOLVO SERVICE ADV
  • 175 POSTS
WHAT KIND OF NOISE? A GRIND? A KNOCK?
Oct 5, 2010 at 6:17 AM
CHELLEBROWN1982
there s a vibration on the brake pedal the noise is like a knocking could it be brake discs
Oct 5, 2010 at 6:53 AM
VOLVO SERVICE ADV
  • 175 POSTS
IF YOU ARE FEELING A VIBRATION WHEN BRAKING, THEN THAT COULD BE THE BRAKE ROTORS THAT MAY BE OVERHEATED/WARPED. AS FAR AS THE KNOCKING NOISE WHEN BRAKING, EXACTLY WHEN DO HEAR THE KNOCK? IS IT WHEN RELEASING BRAKE PEDAL? IS IT RIGHT WHEN MAKING CONTACT WITH THE BRAKE PEDAL? NEED MORE INFO.
Oct 5, 2010 at 10:49 AM
CHELLEBROWN1982
its when pressing down to break the knocking noises its more when you turn corners the knocking is worse thats all i know getting in garage tomorrow as its my day off thanks for your help
Oct 5, 2010 at 9:22 PM
VOLVO SERVICE ADV
  • 175 POSTS
WHEN BRAKES ARE AFTERMARKET, SOMETIMES I HAVE SEEN THEM MAKE KNOCKING NOISES. MAYBE BECAUSE THEY WERE NOT LUBRICATED PROPERLY, OR SIMPLY BECAUSE THEY ARE AFTERMARKET. IF THE BRAKES ARE FACTORY, AND BRAKES WERE LUBRICATED PROPERLY, TYPICALLY THE BRAKES WILL NOT MAKE NOISE.
Oct 6, 2010 at 3:49 AM
