Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Volvo
S40
Ignition
Spark Plug
1997 Volvo S40 no firing on spark plugs
1997 VOLVO S40
49,000 MILES • 4 CYL • FWD • AUTOMATIC
MOHD TASRIF
MEMBER
Engine cranks but the spark plugs does not get the firings
Apr 2, 2008 at 8:03 PM
BLACKOP555
Experienced Mechanic
do you have a rpm reading on the tachometer when cranking the engine? if not theres either an issue with a crank shaft position sensor or bad coils.
you gettign spark directly from the coil?
Jul 15, 2008 at 10:44 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
