Gas smell in car
VOLVO
MAI
What could be the cause of gas smell inside the car? I don't overfill the tank and it lasts about 2, may be 3 days. This happens only when I pump gas and never spill it where it would be obvious that it stinks. Volvo Owners, is this a common problem?
Feb 27, 2006 at 12:44 AM
88VOLVO240GL
I have had a volvo for about 14 months now (88-240GL) and i've noticed, every once in a while when i filled up, the gas smell)
*On my jeep it was caused by a bad fuel injector leaking. May want to check those...
Jul 3, 2006 at 6:50 AM
PAT BROWN
your problem most likely is the result of leaks in the over flow lines the vent vapors from your tank. If they are lose then the smell occurrs
Jul 3, 2006 at 10:05 AM
