1998 Other Volvo Models Gringing Sound when i brake
1998 VOLVO
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
MSCHAEFE
I have a 1998 Volvo S90. I noticed in the past few weeks a grinding noise that occurs every time i brake at around 30 mph or lower. Also there is a vibration that's gotten worse through the steering wheel. It sounds like the noise is only coming from the front wheels. When i release the brakes there is a slight rubbing sound that eventually stops when i get to a higher speed.
Jan 17, 2008 at 9:40 AM
BMRFIXIT
  • 19,053 POSTS
[quote:df8bbc01c9="mschaefe"]Brakes problem
1998 Other Volvo Models 6 cyl Two Wheel Drive Automatic 115000 miles
I have a 1998 Volvo S90. I noticed in the past few weeks a grinding noise that occurs every time i brake at around 30 mph or lower. Also there is a vibration that's gotten worse through the steering wheel. It sounds like the noise is only coming from the front wheels. When i release the brakes there is a slight rubbing sound that eventually stops when i get to a higher speed.[/quote:df8bbc01c9]
I would rush and have the brakes checked sounds like pads going throw the rotors
have the brake check as soon as possible
Jan 17, 2008 at 10:37 AM
