2003 Volvo C70 ignition
55,000 MILES • 4 CYL • FWD • AUTOMATIC
TONY116
ignition starts sometimes but usually wont crank it has got worse since new no volvo dealer can find problem some say chip in key needs to be reset with computer .
it always starts eventually but usually have to lock and unlock car and use another key
Sep 28, 2010 at 6:09 AM
VOLVO SERVICE ADV
  • 175 POSTS
IT SOUNDS LIKE AN IMMOBILIZER FAULT. THERE ARE DIFFERENT REPAIRS FOR THIS CONDITION. IT CAN BE THE IMMOBILIZER ANTENNA RING, IT CAN BE THE CONNECTORS AT THE IMMOBILIZER, OR IT CAN BE A KEY MALFUNCTION. THE FIRST STEP IS TO DETERMINE WETHER THE CONDITION HAPPENS WITH ONE KEY OR BOTH.
Sep 28, 2010 at 1:05 PM
JIS001
  • 3,412 POSTS
If you need to use another key to start your vehicle then most likely your key is bad. Use the other key for a while to see if you get the same problem. Let me know what happens.
Sep 28, 2010 at 1:26 PM
TONY116
thanks for your help its both keys it happens with, does this mean new keys needed and does it have to be volvo dealer?
Sep 29, 2010 at 3:37 AM
VOLVO SERVICE ADV
  • 175 POSTS
IF ITS BOTH KEYS, THEN ITS NOT A MALFUNCTION OF THE KEYS, ITS A MALFUNCTION IN THE IMMOBILIZER SYSTEM: IMMOBILIZER, ANTENNA RING, OR CONNECTORS. A VOLVO DEALER WOULD BE THE NEXT STEP, UNLESS YOU KNOW SOMEBODY THAT CAN PLUG IN THE SYSTEM AND PERFORM A DIAGNOSIS.
Sep 29, 2010 at 4:39 AM
