2001 Volvo C70 eletrical problems
2001 VOLVO C70
71,500 MILES • 4 CYL • FWD • AUTOMATIC
RHARRIS08
I recently try myself to change my head light bulbs, but when i drove my car and tryed using my turn signals and or my high beams they did not work so i went to check the fuses and it was the fuse, but when i replaced the fuse it poped. I tryed replacing the fuse a few more times and the same thing kept happening. so i figure its a short i must have caused when i changed my light bulbs. is there anything i can do to fix the problem or what shall i do? I would very much appreciate anyones insight on this matter.
Thank You, Mr.Rharris
Apr 12, 2008 at 2:06 PM
JIS001
  • 3,412 POSTS
When you replaced the headligt bulb how was the connector to the bulb? Was it very brittle and broke? If it did you may have both terminals toucing one another. Recheck your connector at the headlight bulb you replaced.
May 14, 2009 at 2:01 PM
