2000 Volvo C70 driver window leaking water
115,122 MILES • V12 • FWD • AUTOMATIC
JOHN KNOWLES
window not fitting up to sealcan it be adjusted
Jul 24, 2010 at 5:16 AM
JIS001
  • 3,412 POSTS
Did you replace the window regulator?
Jul 25, 2010 at 5:11 PM
JOHN KNOWLES
dealer who sold car replaced whole window other side fits up to seal and lifts hood slightly driver side needs to go up 2mm more
Jul 31, 2010 at 6:12 AM
JIS001
  • 3,412 POSTS
You need to take it in to the dealership to have the windows reinitialized. There may be a procedure to do it without using the dealer equipment but do not have the info on hand? I will see if I can get that info for you tomorrow?
Aug 1, 2010 at 5:36 PM
JIS001
  • 3,412 POSTS
Checked on the window adjustment and looks like I need a fax number to fax you the instructions. There are 5 pages and I can not copy all the instructions with the pictures. Be easier to just fax? Let me know if that works for you?
Aug 2, 2010 at 2:19 PM
JOHN KNOWLES
thanks but no fax all ihave is email if no good will take to garage u have been very helpfull
Aug 11, 2010 at 7:22 AM
