1999 Volvo C70 Ignition Key
DAVIDHOT
Interior problem
1999 Volvo C70 Front Wheel Drive Automatic
I am unable to remove the key from the ignition. It seems that it wont turn all the way to the off position.
Aug 14, 2009 at 7:51 AM
JIS001
  • 3,412 POSTS
Your gear selector button on the knob could be broken. Play around with the button until it pops back out. You should be able to remove the key then. If this is the problem then you need to replace the gear selector knob.
Aug 16, 2009 at 12:50 PM
