Check to verify your oil is at the proper level. If it is, while the engine is idling and the ticking noise starts, remove the dipstick. If you see air bubbles on the oil then you have an internal oil leak. The oil pan would need to be removed to replace the oil pick up tube seals.
Mar 8, 2010 at 5:17 PM
