1998 Volvo C70 ABS
RAJPAUL
  • 5 POSTS
Brakes problem
1998 Volvo C70 Front Wheel Drive Automatic 110000 miles
I have The ABS and Traction control Lights stays on. does any one know if i need a new control unit or it's just a sensor??
Apr 7, 2008 at 6:39 AM
JIS001
  • 3,412 POSTS
Most likely you will need to replace the control unit. Have the codes read out. Most likely codes will be for rear wheel sensors. If it is and with the scanner you see the wheel speed sensors update while driving then yes it is the control unit. If not then you will need to start looking for a damage sensor or harness? Good luck.
Mar 29, 2009 at 6:51 PM
