1997 Volvo 960 CYLINDER # 5 MISFIRE
1997 VOLVO 960
142,555 MILES • 6 CYL • 2WD • AUTOMATIC
BARKATLA
The motor of my Volvo 960 1997 6 cylinder reer wheel drive started to vibrate and loose power After i diagnostic with OBD II it tell me cylinder # 5 misfire how do i test or repair this problem.
Thank you for your help in advance
Aug 14, 2010 at 2:12 AM
DOCFIXIT
  • 18,828 POSTS
Check for spark if present check compression
Aug 14, 2010 at 5:38 AM
KCPOLLOCK
If the car is still running try this - I had the same problem on my 98 S90 - I suggest changing #5 coil & plug with another cylinder, if the rough running doesn't go away & you still have a code for number 5 cyl., miy problem turned out to be the ignition module. There are two modules, one on either side of the intake manifold. On my S90 the one on the front of the manifold controls cyl 1,3, & 5, changing the unit solved the problem.
Aug 27, 2010 at 1:02 PM
