1997 Volvo 960 confused.
STEPHENIEB
Electrical problem
1997 Volvo 960
I just noticed that my brake lights are not working. I checked the bulbs, and they are fine, all the fuses are fine, my blinkers work, but my brake lights still are not working. What could I do to fix it?
Jun 7, 2009 at 1:51 PM
DONALDGOLDSR
  • 38 POSTS
[quote:02172401ca="stephenieb"]Electrical problem
1997 Volvo 960
I just noticed that my brake lights are not working. I checked the bulbs, and they are fine, all the fuses are fine, my blinkers work, but my brake lights still are not working. What could I do to fix it?[/quote:02172401ca]
the most logical place to start looking would be the brake light switch on the brake pedal arm. I can be tested with a 12 volt light tester. When the pedal is depressed, it should have 12 volts coming from one of the wires, and constant 12 volts coming from the other wire.
Aug 3, 2009 at 2:38 PM
