1997 Volvo 960 Check Engine Light indicator On
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
MYBLUE960
I had the ODB read..light is on due high temp..the cooling fan comes on from 1st initial start up although car hasn't been running..how do you reset the temp control on the engine?
Jul 25, 2008 at 8:53 AM
KHLOW2008
  • 41,812 POSTS
Hi myblue960,
What was the error code? P0116, P0117,P0118?
There is no resetting procedures if the fan circuit is malfunctioning. Either the ECT or fan relay is faulty.
Aug 2, 2008 at 9:22 PM
